maxiq4
January 19, 2012, 8:13pm
1
hello Im using proteus ares not eagle
its created RS274X gerber cadcam out a zip file verywell
but file name extension are *.txt
NOT gtl, gbs ,gto
example:
CADCAM Bottom Copper.TXT
CADCAM Bottom Silk Screen.TXT
CADCAM Drill.TXT
CADCAM Top Copper.TXT
is it acceptable ?
maxiq4
January 21, 2012, 7:48am
3
are you sure this? any try ?
I think proteus and eagles gerber out format arent same.
I use Pulsonix, and all I had to do was rename the Gerber and drill files for ITead Studios. Seeed uses the same PCB supplier.
If Proteus doesn’t produce standard Gerber files, there must be something wrong with it. Have you tried renaming them?
maxiq4
January 21, 2012, 3:13pm
5
hi leon_heller
renaming is easy
but I dont know dataformat same or seedstudio accept it .
may I want help from yours?
could you check this format from yours ?
Im check bottom,top and others files are same to eagles
but drill file is some different !
proteus generate a drill.txt and readme.txt
this is a sample from drill data
the file name is:A2LITE - CADCAM Drill.TXT
M48
INCH
T01C0.0150
T02C0.0200
T03C0.0400
T04C0.0500
T05C0.0450
T06C0.0300
T07C0.1190
T01
X-001650Y+013050
X-003300Y+005550
X+002100Y+005400
X-011250Y+015900
X-005100Y+008400
X-021299Y+008732
X-031350Y+013649
X+001800Y+016500
X-004050Y+008400
X-001650Y+008400
X-019200Y+009750
X-029250Y+013200
X-017100Y+010200
X-013950Y+013500
and this is A2LITE - CADCAM READ-ME.TXT
(full)
LABCENTER PROTEUS TOOL INFORMATION FILE
Tool set up for Proteus layout 'A2LITE.LYT'.
File List
Top Copper : A2LITE - CADCAM Top Copper.TXT
Bottom Copper : A2LITE - CADCAM Bottom Copper.TXT
Top Silk Screen : A2LITE - CADCAM Top Silk Screen.TXT
Bottom Silk Screen : A2LITE - CADCAM Bottom Silk Screen.TXT
Drill : A2LITE - CADCAM Drill.TXT
Photoplotter Setup
Format: RS274X, ASCII, 2.4, imperial, absolute, eob=*, LZO
Notes: D=Diameter, S=Side, W=Width, H=Height
D10 CIRCLE D=0.51mm DRAW
D11 CIRCLE D=0.76mm DRAW
D12 CIRCLE D=1.02mm DRAW
D13 CIRCLE D=1.27mm DRAW
D14 CIRCLE D=1.52mm DRAW
D15 CIRCLE D=0.64mm DRAW
D16 CIRCLE D=1.02mm FLASH
D17 CIRCLE D=1.27mm FLASH
D18 CIRCLE D=1.52mm FLASH
D19 CIRCLE D=2.03mm FLASH
D70 CIRCLE D=1.78mm FLASH
D71 CIRCLE D=2.54mm FLASH
D20 SQUARE S=2.03mm FLASH
D21 SQUARE S=1.9mm FLASH
D22 CIRCLE D=1.9mm FLASH
D23 SQUARE S=1.78mm FLASH
D24 CIRCLE D=3.56mm FLASH
D25 CIRCLE D=0.2mm DRAW
D26 SMT W=1.52mm H=2.54mm FLASH
D27 SMT W=3.81mm H=2.03mm FLASH
D28 SMT W=1.02mm H=1.52mm FLASH
D29 SMT W=1.47mm H=2.54mm FLASH
D72 SMT W=1.52mm H=1.02mm FLASH
D73 CIRCLE D=0.15mm DRAW
D30 CIRCLE D=2.29mm FLASH
D31 CIRCLE D=3.3mm FLASH
D32 SMT W=2.54mm H=2.54mm FLASH
D33 SMT W=2.41mm H=2.41mm FLASH
D34 CIRCLE D=2.41mm FLASH
D35 SMT W=2.29mm H=2.29mm FLASH
D36 SMT W=2.03mm H=3.05mm FLASH
D37 SMT W=4.32mm H=2.54mm FLASH
D38 SMT W=1.52mm H=2.03mm FLASH
D39 SMT W=1.98mm H=3.05mm FLASH
D40 SMT W=2.03mm H=1.52mm FLASH
NC Drill Setup
Format: ASCII, 2.4, imperial, absolute, eob=<CR><LF>, no zero suppression.
Notes: Tool sizes are diameters. Layer sets are in brackets - 0=TOP, 15=BOTTOM, 1-14=INNER.
T01 0.38mm (0-15)
T02 0.51mm (0-15)
T03 1.02mm (0-15)
T04 1.27mm (0-15)
T05 1.14mm (0-15)
T06 0.76mm (0-15)
T07 3.02mm (0-15)
[END OF FILE]
Here is one of my .gtl (Top Layer) files:
G04 GENERATED BY PULSONIX 7.0 GERBER.DLL 4573*
%INPROTO*%
%LNTOP*%
%FSLAX35Y35*%
%IPPOS*%
%LPD*%
%OFA0B0*%
%MOIN*%
%ADD10C,0.01200*%
%ADD20C,0.05000*%
%ADD22C,0.05512*%
%ADD26C,0.05906*%
%ADD244C,0.03000*%
%ADD262C,0.14173*%
X0Y0D02*
D02*
D10*
X22900Y200250D02*
X357900D01*
Y27750*
X22900*
Y200250*
X110400Y95250D02*
X85400D01*
X72900Y107750*
X110400Y95250D02*
X102900Y102750D01*
Y162750*
X105400Y165250*
X247900*
X267900Y185250*
X110400Y155250D02*
Y102750D01*
X115400Y97750*
Y47750*
X120400Y42750*
Y155250D02*
Y102750D01*
X125400Y97750*
Y47750*
X130400Y42750*
Y155250D02*
Y102750D01*
X135400Y97750*
Y47750*
X140400Y42750*
Y155250D02*
Y102750D01*
X145400Y97750*
Y47750*
X150400Y42750*
Y155250D02*
Y102750D01*
X155400Y97750*
Y47750*
X160400Y42750*
Y155250D02*
Y102750D01*
X165400Y97750*
Y47750*
X170400Y42750*
Y155250D02*
Y102750D01*
X175400Y97750*
Y47750*
X180400Y42750*
Y155250D02*
Y102750D01*
X185400Y97750*
Y47750*
X190400Y42750*
X220400Y170250D02*
X232900D01*
X237900Y175250*
Y185250*
X230400Y155250D02*
Y112750D01*
X245400Y97750*
Y75250*
X242900Y72750*
X205400*
X195400Y62750*
Y47750*
X200400Y42750*
X240400Y155250D02*
Y112750D01*
X255400Y97750*
Y72750*
X252900Y70250*
X210400*
X205400Y65250*
Y47750*
X210400Y42750*
X250400Y155250D02*
Y112750D01*
X265400Y97750*
Y70250*
X262900Y67750*
X220400*
X215400Y62750*
Y47750*
X220400Y42750*
X260400Y155250D02*
Y112750D01*
X275400Y97750*
Y67750*
X272900Y65250*
X227900*
X225400Y62750*
Y47750*
X230400Y42750*
X270400Y155250D02*
Y115250D01*
X285400Y100250*
Y65250*
X282900Y62750*
X237900*
X235400Y60250*
Y47750*
X240400Y42750*
X280400Y155250D02*
Y115250D01*
X295400Y100250*
Y62750*
X292900Y60250*
X247900*
X245400Y57750*
Y47750*
X250400Y42750*
X290400Y155250D02*
Y112750D01*
X305400Y97750*
Y60250*
X302900Y57750*
X257900*
X255400Y55250*
Y47750*
X260400Y42750*
X300400Y155250D02*
Y107750D01*
X307900Y100250*
Y50250*
X305400Y47750*
X265400*
X260400Y52750*
D02*
D20*
X82900Y160250D03*
Y185250D03*
X210400Y135250D03*
X220400Y170250D03*
D02*
D22*
X62900Y175250D03*
Y185250D03*
X72900Y107750D03*
Y147750D03*
X92900Y125250D03*
Y135250D03*
X110400Y95250D03*
Y155250D03*
X120400Y95250D03*
Y155250D03*
X130400Y95250D03*
Y155250D03*
X140400Y95250D03*
Y155250D03*
X150400Y95250D03*
Y155250D03*
X160400Y95250D03*
Y155250D03*
X170400Y95250D03*
Y155250D03*
X180400Y95250D03*
Y155250D03*
X190400Y95250D03*
Y155250D03*
Y175250D03*
X200400Y95250D03*
Y155250D03*
Y175250D03*
X210400Y95250D03*
Y155250D03*
X220400Y77750D03*
Y95250D03*
Y155250D03*
X230400Y77750D03*
Y95250D03*
Y155250D03*
X240400Y77750D03*
Y95250D03*
Y155250D03*
X250400Y95250D03*
Y155250D03*
X260400Y95250D03*
Y155250D03*
X270400Y95250D03*
Y155250D03*
X280400Y95250D03*
Y155250D03*
X290400Y95250D03*
Y155250D03*
X300400Y95250D03*
Y155250D03*
D02*
D26*
X50400Y135250D03*
Y145250D03*
X110400Y42750D03*
Y52750D03*
X120400Y42750D03*
Y52750D03*
X130400Y42750D03*
Y52750D03*
X140400Y42750D03*
Y52750D03*
X150400Y42750D03*
Y52750D03*
X160400Y42750D03*
Y52750D03*
X170400Y42750D03*
Y52750D03*
X180400Y42750D03*
Y52750D03*
X190400Y42750D03*
Y52750D03*
X200400Y42750D03*
Y52750D03*
X210400Y42750D03*
Y52750D03*
X217900Y185250D03*
X220400Y42750D03*
Y52750D03*
X227900Y185250D03*
X230400Y42750D03*
Y52750D03*
X237900Y185250D03*
X240400Y42750D03*
Y52750D03*
X247900Y185250D03*
X250400Y42750D03*
Y52750D03*
X257900Y185250D03*
X260400Y42750D03*
Y52750D03*
X267900Y185250D03*
X270400Y42750D03*
Y52750D03*
D02*
D244*
X82900Y185250D02*
Y160250D01*
X92900Y135250D02*
X75400D01*
X62900Y122750*
Y40250*
X67900Y35250*
X267900*
X270400Y37750*
Y42750*
X190400Y175250D02*
Y190250D01*
X192900Y192750*
X255400*
X257900Y190250*
Y185250*
X210400Y135250D02*
Y95250D01*
X230400Y77750D02*
X220400Y87750D01*
Y95250*
D02*
D262*
X35400Y40250D03*
Y187750D03*
X345400Y40250D03*
Y187750D03*
X0Y0D02*
M02*
Here is my drill file (.txt) for the same board:
M48
INCH
T01C000.03000
T02C000.03150
T03C000.03543
T04C000.11811
M70
T01
X00082900Y00160250
X00082900Y00185250
X00210400Y00135250
X00220400Y00170250
T02
X00062900Y00175250
X00062900Y00185250
X00072900Y00107750
X00072900Y00147750
X00092900Y00125250
X00092900Y00135250
X00110400Y00095250
X00110400Y00155250
X00120400Y00095250
X00120400Y00155250
X00130400Y00095250
X00130400Y00155250
X00140400Y00095250
X00140400Y00155250
X00150400Y00095250
X00150400Y00155250
X00160400Y00095250
X00160400Y00155250
X00170400Y00095250
X00170400Y00155250
X00180400Y00095250
X00180400Y00155250
X00190400Y00095250
X00190400Y00155250
X00190400Y00175250
X00200400Y00095250
X00200400Y00155250
X00200400Y00175250
X00210400Y00095250
X00210400Y00155250
X00220400Y00077750
X00220400Y00095250
X00220400Y00155250
X00230400Y00077750
X00230400Y00095250
X00230400Y00155250
X00240400Y00077750
X00240400Y00095250
X00240400Y00155250
X00250400Y00095250
X00250400Y00155250
X00260400Y00095250
X00260400Y00155250
X00270400Y00095250
X00270400Y00155250
X00280400Y00095250
X00280400Y00155250
X00290400Y00095250
X00290400Y00155250
X00300400Y00095250
X00300400Y00155250
T03
X00050400Y00135250
X00050400Y00145250
X00110400Y00042750
X00110400Y00052750
X00120400Y00042750
X00120400Y00052750
X00130400Y00042750
X00130400Y00052750
X00140400Y00042750
X00140400Y00052750
X00150400Y00042750
X00150400Y00052750
X00160400Y00042750
X00160400Y00052750
X00170400Y00042750
X00170400Y00052750
X00180400Y00042750
X00180400Y00052750
X00190400Y00042750
X00190400Y00052750
X00200400Y00042750
X00200400Y00052750
X00210400Y00042750
X00210400Y00052750
X00217900Y00185250
X00220400Y00042750
X00220400Y00052750
X00227900Y00185250
X00230400Y00042750
X00230400Y00052750
X00237900Y00185250
X00240400Y00042750
X00240400Y00052750
X00247900Y00185250
X00250400Y00042750
X00250400Y00052750
X00257900Y00185250
X00260400Y00042750
X00260400Y00052750
X00267900Y00185250
X00270400Y00042750
X00270400Y00052750
T04
X00035400Y00040250
X00035400Y00187750
X00345400Y00040250
X00345400Y00187750
M30
Your drill file looks different from mine. Don’t send the Readme file.
maxiq4
February 1, 2012, 10:32pm
8
I send the files to seed (with change name)
and Im waiting already
Yes, although we note that the gerber file must be RS-274x format, but if your design meet with requirement ,we also accept it .
Regards,
Dingding
maxiq4
February 16, 2012, 7:09am
10
hi
you send me finished pcb 9 february 2012, thank you
but now (after 8 days later) no any pcb received and “I can not track too”
I can not see any information about pcb on the tracking post web
where are the pcb`s I dont know
I send 3 email to you
but answers inadequate
someone check my pcb`s please
my project soooo late
order number is 43002
sorry but its very urgent
It can take 10 days or more for PCBs to reach me here in the UK, from when they are posted. The tracking works for me, but it isn’t very informative.
hi there,
sorry for the inconvenience, your goods have been shipped on 9 February 2012, this is the tracking number:RT125516376HK, but now the searching website update slowly, so please wait some days to try again.
regards,
dingding
maxiq4
February 22, 2012, 3:04pm
13
finally its received today
its looking good
thank you
and @leon_heller thank you too
