program Seeeduino Ethernet using a FTDI cable?
Is it possible to use a FTDI cable (or breakout) to program the Seeeduino Ethernet board (instead of using UartSBee)?
Thank you!
Should be, the pinout for that 6pin header is realtively common. Main item to watch out for is the FTDI cable brings out RTS instead of DTR.
Also, the UartSBee is an FTDI breakout that features sockets to mount an XBee for programming; it is a dual purpose item if you ever intend to use XBees.
