Possible implementation of Circuitpython Library to use with Groove Vision AI V2
I’m doing an experiment, creating a class to communicate between a Xiao board with Circuitpython and GrooveVision AI V2, but I haven’t been able to communicate successfully yet.
I initially tried the UART protocol, because the list of commands available at this link SSCMA-Micro/docs/protocol/at_protocol.md at dev · Seeed-Studio/SSCMA-Micro · GitHub gave me to understand that the communication was done this way.
Using UART I get the message that TX is in use.
Using I2C I get null message.
Using SPI, I get the message that CS is in use.
    Circuitpython SSCMA Test Library
    Implement this command list:
    AT+MQTTPUBSUB? 	Get current MQTT publish and subscribe topic
    AT+MQTTSERVER? 	Get current MQTT server status and config
    AT+MQTTSERVERSTA=<STA> Set MQTT server status
    AT+MQTTSERVER=<"CLIENT_ID","ADDRESS",PORT,"USERNAME","PASSWORD",USE_SSL> Set and connect to a MQTT server
    AT+WIFI? Get current Wi-Fi status and config
    AT+WIFIVER? Get Wi-Fi version
    AT+WIFIVER=<VER> Set Wi-Fi version
    AT+WIFIIN6=<"IP"> Set IPv6 info
    AT+WIFIIN4=<"IP","NETMASK","GATEWAY"> Set IPv4 info
    AT+WIFISTA=<STA> Set Wi-Fi status
    AT+WIFI=<"NAME",SECURITY,"PASSWORD"> Set and connect to a Wi-Fi
    AT+INFO? Get info string from device flash
    AT+INFO=<"INFO_STRING">  Store info string to device flash
    AT+ACTION? Get action trigger
    AT+ACTION=<"EXPRESSION"> Set action trigger
    AT+INVOKE? Get invoke task status
    AT+INVOKE=<N_TIMES,DIFFERED,RESULT_ONLY> Invoke for N times (-1 for infinity loop)
    AT+SAMPLE? Get sample task status
    AT+SAMPLE=<N_TIMES> Sample data from current sensor
    AT+SENSOR? Get current sensor info
    AT+SENSOR=<SENSOR_ID,ENABLE/DISABLE,OPT_ID>  Set a default sensor by sensor ID
    AT+SENSORS? Get available sensors
    AT+ALGO?Get current algorithm info
    AT+ALGO=<ALGORITHM_ID> Set a algorithm by algorithm type ID
    AT+ALGOS? Get available algorithms
    AT+MODEL? Get current model info
    AT+MODEL=<MODEL_ID> Load a model by model ID
    AT+MODELS? Get available models
    AT+LED=<ENABLE/DISABLE> Set LED status
    AT+YIELD=<TIME_S>
import time, board, busio, json
# This Library still is not functional. Get TX in use, and can't create UART
class ATDevice:
    def __init__(self, uart):
        self.uart = uart
        self._msg_buffer = b''
        self.listeners = []
    def send_command(self, command, tag=None, timeout=1):
        if tag:
            full_command = f'AT+{tag}@{command}\r'
        else:
            full_command = f'AT+{command}\r'
        self.uart.write(full_command.encode('utf-8'))
        time.sleep(timeout)
        return self._read_response()
    def _read_response(self):
        response = []
        while self.uart.in_waiting > 0:
            response.append(self.uart.readline().decode('utf-8').strip())
        response = ''.join(response)
        return self._parse_json(response)
    def _parse_json(self, response):
        try:
            return json.loads(response)
        except json.JSONDecodeError:
            print("Failed to decode JSON response.")
            return None
    def _handle_response(self, response):
        if response is None:
            return "Invalid JSON response"
        response_type = response.get("type", None)
        command_name = response.get("name", None)
        response_code = response.get("code", None)
        data = response.get("data", None)
        if response_type is None or command_name is None or response_code is None:
            return "Malformed response"
        if response_code == 0:
            return data
        else:
            return f"Error {response_code}: {self._get_error_message(response_code)}"
    def _get_error_message(self, code):
        error_messages = {
            0: "Success",
            1: "Try again",
            2: "Logic error",
            3: "Timeout",
            4: "IO error",
            5: "Invalid argument",
            6: "Out of memory",
            7: "Busy",
            8: "Not supported",
            9: "Operation not permitted"
        return error_messages.get(code, "Unknown error")
    # Command functions
    def get_mqtt_pubsub(self):
        response = self.send_command('MQTTPUBSUB?')
        return self._handle_response(response)
    def get_mqtt_server(self):
        response = self.send_command('MQTTSERVER?')
    def set_mqtt_server_status(self, status):
        response = self.send_command(f'MQTTSERVERSTA={status}')
    def set_mqtt_server(self, client_id, address, port, username, password, use_ssl):
        response = self.send_command(f'MQTTSERVER="{client_id}","{address}",{port},"{username}","{password}",{use_ssl}')
    def get_wifi_status(self):
        response = self.send_command('WIFI?')
    def get_wifi_version(self):
        response = self.send_command('WIFIVER?')
    def set_wifi_version(self, version):
        response = self.send_command(f'WIFIVER={version}')
    def set_wifi_ipv6(self, ip):
        response = self.send_command(f'WIFIIN6="{ip}"')
    def set_wifi_ipv4(self, ip, netmask, gateway):
        response = self.send_command(f'WIFIIN4="{ip}","{netmask}","{gateway}"')
    def set_wifi_status(self, status):
        response = self.send_command(f'WIFISTA={status}')
    def connect_wifi(self, name, security, password):
        response = self.send_command(f'WIFI="{name}",{security},"{password}"')
    def get_device_info(self):
        response = self.send_command('INFO?')
    def set_device_info(self, info_string):
        response = self.send_command(f'INFO="{info_string}"')
    def get_action_trigger(self):
        response = self.send_command('ACTION?')
    def set_action_trigger(self, expression):
        response = self.send_command(f'ACTION="{expression}"')
    def get_invoke_status(self):
        response = self.send_command('INVOKE?')
    def invoke_task(self, n_times, differed, result_only):
        response = self.send_command(f'INVOKE={n_times},{differed},{result_only}')
    def get_sample_status(self):
        response = self.send_command('SAMPLE?')
    def sample_data(self, n_times):
        response = self.send_command(f'SAMPLE={n_times}')
    def get_sensor_info(self):
        response = self.send_command('SENSOR?')
    def set_sensor(self, sensor_id, enable, opt_id):
        response = self.send_command(f'SENSOR={sensor_id},{enable},{opt_id}')
    def get_available_sensors(self):
        response = self.send_command('SENSORS?')
    def get_algorithm_info(self):
        response = self.send_command('ALGO?')
    def set_algorithm(self, algorithm_id):
        response = self.send_command(f'ALGO={algorithm_id}')
    def get_available_algorithms(self):
        response = self.send_command('ALGOS?')
    def get_model_info(self):
        response = self.send_command('MODEL?')
    def set_model(self, model_id):
        response = self.send_command(f'MODEL={model_id}')
    def get_available_models(self):
        response = self.send_command('MODELS?')
    def set_led_status(self, status):
        response = self.send_command(f'LED={status}')
    def yield_time(self, time_s):
        response = self.send_command(f'YIELD={time_s}')
    def _handle_incoming_data(self, data):
        self._msg_buffer += data
        matches = re.findall(b'\r{.*}\n', self._msg_buffer)
        for match in matches:
            try:
                payload = json.loads(match.decode('utf-8'))
                if "type" in payload:
                    for listener in self.listeners:
                        if listener["name"] == payload["name"]:
                            listener["response"] = payload
                            listener["event"].set()
            except Exception as ex:
                print(f"Failed to handle incoming data: {ex}")
            finally:
                self._msg_buffer = self._msg_buffer[self._msg_buffer.find(b'\n')+1:]
# Exemplo de uso:
uart = busio.UART(board.TX, board.RX, baudrate=921600)
device = ATDevice(uart)
# Obter status atual do Wi-Fi
print(device.get_wifi_status())
I also confirm that the above commands work via serial terminal, with USB connection, using Minicom, Putty or Tera Term.
The command list gives us the impression that it would be possible to switch between models installed on the board, but this does not appear to have been implemented via Sensecraft AI.
I was able to get a modified version of this going with a XIAO NRF52480 board. You do need to press the RST button on the GROVE AI board in case it’s hung up.
DEBUG=False
class ATDevice:
        self.uart = uart
        self._response_buffer = bytearray(1024)
        self._mv = memoryview(self._response_buffer)
        if tag:
        else:
        if DEBUG:
            print(f"=> {full_command}")
        time.sleep(timeout)
        resp = self._read_response()
        if DEBUG:
            print(f"<- {resp}")
        return resp
        index = 0
        while True:
            if self.uart.in_waiting == 0:
                continue
            bytes_read = self.uart.readinto(self._mv[index:])
            if DEBUG:
                print(f"Read {bytes_read} bytes: {self._response_buffer[index:index+bytes_read]}")
            index += bytes_read
            if "}\n" in self._response_buffer[:index]:
                break
        response = self._response_buffer[:index].decode('utf-8').strip()
        try:
        except ValueError:
            print(f"Failed to decode JSON response {response}")
            return None
            return data
        else:
        error_messages = {
            0: "Success",
            1: "Try again",
            2: "Logic error",
            3: "Timeout",
            4: "IO error",
            6: "Out of memory",
            7: "Busy",
            8: "Not supported",
uart = busio.UART(board.TX, board.RX, baudrate=921600, receiver_buffer_size=1024)
