I use Relay control one pump(220V 30w), but I only control it open and cant close, relay light is normal,I think it’s destroyed。Before this, I can correctly control the LED light(220V 20W) on and off.When Its destroyed and cant control Led light anymore…I’m wired correctly and I test many times。That’s what bothers me,have someone konw why?
What are the specific products? Can you provide some links? Let me check the parameters for you.
https://item.taobao.com/item.htm?spm=a1z09.2.0.0.67142e8d0h9v0X&id=521709608830&_u=d1fron4ka8e2,The pumps I used,some of them can only be controlled once, and some can be controlled several times, but all of them can’t be closed again after being opened,thanks Baozhu.
emmm…, This is not a Seeed product, and we haven’t researched and used it.Sorry I didn’t help you.
It’s not your fault, it may be my misunderstanding. This is the relay product I used, which belongs to our company.https://www.seeedstudio.com/DockerPi-4-Channel-Relay-p-4096.html
I use this relay to control the pumps I mentioned above, and it doesn’t work properly。Can only switch these pumps on and off a few times, and then they won’t shut off properly
