pH Sensor example code zip file has no code?
Hi Seeedstudio,
Can you provide the example code that is supposed to be in the
Grove-PH_Sensor_kit.zip file.
I have downloaded it a couple of times but there is nothing there.
Also tried to use a zip repair utility and it also showed no files are zipped up there.
I need example code for the Grove (analog) pH Sensor & ORP Sensors I just purchased.
Thanks.
Joe
I can’t find a link to Grove-PH_Sensor_kit.zip in the wiki documentation, I can help you if you can point it out.
