Played around with pfsense on the Odyssey fo a few days and I initially assumed the fan was not running due to low stress but I have come to find that it just does not operate running pfsense. Not sure but seeing that you advertise that this unit will run this and the fact that it can cook the board is not a good thing. My unit may be cooked as now it wont even install an os. Got any ideas? Worked till the heat got to it.
Ok so I pulled out the disk i put Fedora on plugged it and that still runs + fan operates there. pushing youtube fan is on constant at 45c to 54c
@ernieboxer Therefore, when running pfSense, the CPU temperature is not high.
Bad drive! Bad drive!
