Hi I just got the new reRouter and trying to set up wireguard,
I changed the IP to a static 192.168.1.100 and then when I went change it again it again, Changes could not be made. Apply request failed. Same when I tried turning back on the radio etc.
In putty I cannot make any changes
Seems locked and read only?
Please help[
Q5: How do I fix my device when I faced the “Read Only Root filesystem”?¶
For devices in the “Read Only Root filesystem”, we can use e2fsck to check the system and fix it. Please open the terminal window and run the following command:
Copied to clipboard
e2fsck /dev/mmcblk0p2
found this and got to work with built in termal, putty didn't work for me
