I just bought the reTerminal, OS etc… everything is fine but when I connect the micro hdmi cable I get nothing on the second monitor. (I’m sure of the safety of the micro hd cable.)
Do you need special settings in the operating system?
Hello, we have also encountered your problem. reTerminal does not require special settings in the OS. We recommend that you test with a different HDMI screen, and that you do not use HDMI to VGA.
Hi
Thank you, I will test again and tell the result here.
The problem was solved by changing the HDMI cable.
