Hi Seeed Team,
Thank you for your support.
I got the customer has error for solar sensor communication.
It didn’t I2C (Solar sensor) device didn’t verify Base Hat (It didn’t detect I2C).
The customer think Sensor is defect.
He try running farmbeats-datastreamer’s main.py,
Error message is appear like this below.
unlightSensor.setup: Please check if the I2C device insert in I2C of Base Hat
SunlightSensor.read: ‘NoneType’ object has no attribute ‘ReadVisible’
I don’t know sensor’s initial fialure or He needs to install some program before or not.
Can you give some advice?
Kind Regards,
Takashi
T4662752
takashi
2
Hi @Takashi69 ,
It appears that I2C communication with the sunlight sensor is not possible.
How about checking if the sensor can be recognized using the i2cdetect -y 1 command?
@takashi san
i2cdetect -y 1 command was verified.
The customer is requesting
*Can you send the data which is in the MicroSD?
He could be mistake when setting during program setting which is able to get Rate from each sensor.
Kind Regards,
Takashi(敬史)
takashi
4
Hi @Takashi69 ,
Is this what you want?
What version of the sensor do you have V1.0 or V2.0
@cgwaltney -san
Can you let us know how to check the version?
Takashi
look on board silk screen
@takashi san
Thank you so much!
The customer solved this case from your file.
I applicate your support.
Kind Regards,
Takashi
@cgwaltney san
Thank you so much!
The customer said He couldn’t read small letters. But Thank you so much.
Please close this case.
Kind Regards,
Takashi
@takashi -san,
The customer replied now error is solved.
Thank you so much!
But…, Still has issue to get data for excel. (Manual explained It can use right away after connecting.)But, it won’t.
And also, We can read Sensor Rate. But we can’t get that data.
Can you let us know how to set up or manual for this type of situation?
Kind Regards,
Takashi
Hi @Takashi69 ,
Unfortunately, I don’t know.
The customer sent screen shot for Serial communication error.
It seems like port wasn’t settled.
Kind Regards,
Takashi
Anybody can help this?
Is it possibly defective?
Kind Regards,
Takashi
It takes a month. Is anybody have idea to solve this case?
Thank you for your patience.
Kind regards,
