So i just received my board and wanted to check it out but it keeps crashing on starting the kernell…
Below is the full console log.
U-Boot 2019.04-g7c1d8e17-dirty (Dec 26 2019 - 05:50:56 +0000)
CPU: Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 43C
Reset cause: POR
Model: Freescale i.MX6 ULL 14x14 EVK Board
Board: MX6ULL 14x14 EVK
DRAM: 512 MiB
NAND: ID read error
0 MiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from MMC… *** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
switch to partitions #0, OK
mmc1(part 0) is current device
flash target is MMC:1
Net:
Error: ethernet@020b4000 address not set.
Error: ethernet@02188000 address not set.
eth-1: ethernet@020b4000
, eth-1: ethernet@02188000
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot: 0
mmc0 is current device
Scanning mmc 0:1…
Checking for: /uEnv.txt …
1552 bytes read in 10 ms (151.4 KiB/s)
Loaded environment from /uEnv.txt
Importing environment from mmc …
Checking if uenvcmd is set …
Checking if client_ip is set …
Checking for: /boot.scr …
Checking for: /boot/boot.scr …
Checking for: /boot/uEnv.txt …
debug: [dtb=imx6ull-seeed-npi.dtb] …
Using: dtb=imx6ull-seeed-npi.dtb …
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
loading /vmlinuz-4.19.71-imx-r1 …
debug: [enable_uboot_overlays=1] …
debug: [uboot_base_dtb=] …
loading /dtbs/4.19.71-imx-r1/imx6ull-seeed-npi.dtb …
38661 bytes read in 12 ms (3.1 MiB/s)
uboot_overlays: [fdt_buffer=0x60000] …
DTOVERLAY[debug]: param no:5 0x83000000 0x88000000 uEnv.txt 0x80800000
DTOVERLAY[debug]: ** uEnv.txt file length:0x610
DTOVERLAY[debug]: ** /lib/firmware/imx-fire-led-overlay.dtbo file length:0x615
loading overlay:/lib/firmware/imx-fire-led-overlay.dtbo
DTOVERLAY[debug]: ** /lib/firmware/imx-fire-lcd5-overlay.dtbo file length:0x175f
loading overlay:/lib/firmware/imx-fire-lcd5-overlay.dtbo
DTOVERLAY[debug]: ** /lib/firmware/imx-fire-sound-overlay.dtbo file length:0xd72
loading overlay:/lib/firmware/imx-fire-sound-overlay.dtbo
DTOVERLAY[debug]: ** /lib/firmware/imx-fire-key-overlay.dtbo file length:0x336
loading overlay:/lib/firmware/imx-fire-key-overlay.dtbo
DTOVERLAY[debug]: ** /lib/firmware/imx-fire-mpu6050-overlay.dtbo file length:0x34e
loading overlay:/lib/firmware/imx-fire-mpu6050-overlay.dtbo
DTOVERLAY[debug]: ** /lib/firmware/imx-fire-18b20-overlay.dtbo file length:0x30e
loading overlay:/lib/firmware/imx-fire-18b20-overlay.dtbo
DTOVERLAY[debug]: ** /lib/firmware/imx-fire-hdmi-overlay.dtbo file length:0xade
loading overlay:/lib/firmware/imx-fire-hdmi-overlay.dtbo
DTOVERLAY[debug]: ** /lib/firmware/imx-fire-dht11-overlay.dtbo file length:0x30e
loading overlay:/lib/firmware/imx-fire-dht11-overlay.dtbo
7982616 bytes read in 363 ms (21 MiB/s)
loading /initrd.img-4.19.71-imx-r1 …
4710916 bytes read in 220 ms (20.4 MiB/s)
debug: [console=ttymxc0 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 vt.global_cursor_default=0 quiet] …
debug: [bootz 0x80800000 0x88000000:47e204 0x83000000] …
Kernel image @ 0x80800000 [ 0x000000 - 0x79ce18 ]
Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
Using Device Tree in place at 83000000, end 8303cfff
Modify /soc/aips-bus@2200000/epdc@228c000:status disabled
ft_system_setup for mx6
Starting kernel …
[ 1.531554] fec 20b4000.ethernet: Invalid MAC address: 00:00:00:00:00:00
[ 1.605788] fec 2188000.ethernet: Invalid MAC address: 00:00:00:00:00:00
[ 1.848889] cpu cpu0: running cpufreq without cooling device: 0
[ 1.960697] sii902x 1-0039: Sii902x: cound not find device
CPU: Industrial temperature grade (-40C to 105C) at 44C
Reset cause: POR
DRAM: 512 MiB
NAND: ID read error
0 MiB
In: serial
Out: serial
Err: serial
Net:
Fastboot: Normal
Normal Boot
Scanning mmc 0:1…
4710916 bytes read in 219 ms (20.5 MiB/s)
Starting kernel …
[ 1.531406] fec 20b4000.ethernet: Invalid MAC address: 00:00:00:00:00:00
[ 1.605557] fec 2188000.ethernet: Invalid MAC address: 00:00:00:00:00:00
[ 1.846691] cpu cpu0: running cpufreq without cooling device: 0
[ 1.951126] sii902x 1-0039: Sii902x: cound not find device
Setting it to boot from SD card instead doesn’t help:
U-Boot 2019.04-g7c1d8e17-dirty (Jan 16 2020 - 11:30:16 +0000)
CPU: Industrial temperature grade (-40C to 105C) at 42C
Reset cause: POR
DRAM: 512 MiB
NAND: ID read error
0 MiB
WARNING:init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh
In: serial
Out: serial
Err: serial
flash target is MMC:0
It probably has something to do with the bold line…
Tried reflashing the SD card with the latest image, but no difference.
But odd thing is that the console complains about missing SD card when boot is set to eMMC and no SD is present…
So maybe the jumpers aren’t read properly?
Either way, this isn’t the buildquality I’d expect from Seeed (is any Q&A done?)
There’s barely any solder on those pins (which i think are power pins)
And the placement seems a little bit off (but i’m new so cant post picture).
