I have tried every forum and help section process I can find to resolve the fact that Windows acknowledges the connection of the Xiao board to the computer yet Arduino IDE doesn’t connect with it.
Windows asking for drivers for the board. NO found solution yet works. Can I please get the actual driver file?
you can try checking drp.su from there you can get drivers!
If Windows asks for drivers, it means it couldn’t find suitable ones automatically. You might need to install couples personal training them manually. Sometimes, the drivers are included with the Arduino IDE. They’re typically located in the Arduino installation directory under "drivers.
If your computer can recognize the port, then Arduino will also display port information. If not, please refer to this Wiki page to find the corresponding solution based on the XIAO you are using. Resolve the issue by entering the Bootloader mode.
