I have tried every example on o\your wiki site to get the lmusic shield up and running sometimes i get a green led and sometimes i get both a red and green led. What I do not get is any audio. My board is a Arduino Duemilanove. I have a 8 gigabyte micro sd card with one test song on it. What I have in mind is a program to run an audio track and and control switch on a relay to run an automation with the music or sound. The play music with name example seems perfect for the job but I can’t get it to work. What am I doing wrong?
Hello ,
What exactly is your problem when use music shield ?
BTW , have you used it following the wiki page ?http://seeedstudio.com/wiki/Music_Shield
Adn you can just directly following the content " Demo 1: Use SD library" of wiki , ignore other contents
Waiting for you reply.
Deray
I followed your instructions and it worked just great. Can I get to play audio tracks by name. I want to incorporate it into a program that will trip a relay to
start an automation motor then play a tract to accompany the action. Also, are there free pins on the Arduino when the music shield is being used?
Hi,Dear
You can refer to this web site:http://www.seeedstudio.com/forum/viewtopic.php?f=4&t=3954.Might it would be helpful to you.
