Hello! I am currently creating the Grove MIX8410 PCB from scratch, but I just realized that some SMD part is not exactly the same as the picture below.
Ex: I use 101 SMD with 5% tolerance for 100R resistor, not 01A SMD with 1% tolerance. Is it okay? will it alter the sensor readings? or even damaged it?
Thank you!
