it seems the dht20.py library is missing on the component wiki page
There is a visible green link that leads to other file that is using the library, not being the library itself.
Best Regards,
BM
Best Regards,
BM
In my case there was a message. ‘This type of file can harm your computer’. Hope seedstudio will look into this matter.
The linked file is clearly incorrect. Additionally, the instructions in the manual for Raspberry are misleading (copy-pasted from a different page and not edited properly). I am spending hours looking for a different source just to run this basic component. That all was supposed to be so easy ![]()
I urge to seeedstudio team to take a look at this discussion and solve this problem.
Sorry for the long wait, I have noticed the problem and I will urge the engineers to change the link to the library as soon as possible, please wait.
I see that the code base is linked inside our resources section and you can use it first.
https://files.seeedstudio.com/wiki/Grove-Temperature-Humidity-Sensor/Pico-micropython-master.zip
Is here a solution for, I have the same error after following the instructions and corrected dht20.py.
