Does the MilCandy have a bootloader flashed into it already? (I have been unable to get avrdude/arduino tools to communicate with it).
Thanks,
Dale
hey,the firmware have been posted on our wiki:http://www.seeedstudio.com/wiki/MilCandy, and you need a UartSBee to communicate with MilCandy.
Thanks, indeed there is a bootloader (some variant of the ATmegaBOOT_168_pro_8MHz.hex based on the hex dump I got).
Apparently the install of Arduino on WinXP did not properly interface with UartSBee, but the Linux variant that I just tried does indeed correctly connect/download to MilCandy.
FYI it would be nice if the pads on the bottom of the board for an AVR programmer were aligned to a normal berg header. Understandably due to board density they can’t actually be thru-hole via’s.
Thanks again,
Dale
