I’m interested in outputing frequencies that are not dependent upon integer period assignments commonly used for timer recipes to toggle a pin. For example, you can use the SAMD51 timer library which accepts an integer argument in microseconds. This works fine for approximate frequencies but ultimately breaks down at moderate frequencies into the kHz range.
Optivolt-Labs has a library that compiles and appears to work on the Adafruit M4 platforms which also use the SAMD51 chip. With that said, the compilation of the following fails on the Wio Terminal as the GClk variable is not defined (at a minimum). This is getting beyond my level of knowlege and was hoping someone might be able to aid in identifying how to access this clock using the Wio Terminal?
Below is an example .ino that works for the Adafruit platform but not the Wio Terminal.
#include <Arduino.h>
#include "mpwm.h"
// valid GCLK value depends on which internal clock you want to use
// some of them are used by arduino core or in other libs, it's worth poking around
// arduino core to double check since it sometimes varies from board to board
// personally found GCLK2 to be a safe bet
MPwm::MatchPwm pwm_signal = MPwm::MatchPwm(33, MPwm::GClk::GCLK2);
pinMode(30, OUTPUT);
// set pwm to some default value to start with
pwm_signal.enable();
pwm_signal.write(.5, 100000); // 50% duty cycle at 100000Hz
float max_freq = 150000;
float min_freq = 50000;
float freq_stp = 10000;
bool increase_duty = true;
if(increase_duty) {
float freq_target = pwm_signal.getFrequency() + freq_stp;
if (freq_target > max_freq) {
increase_duty = false;
} else {
pwm_signal.setFrequency(freq_target);
} else {
float freq_target = pwm_signal.getFrequency() - freq_stp;
if (freq_target < min_freq) {
} else {
Here’s the error trace for the Wio Terminal:
In file included from /Users/gandalf/Library/Arduino15/packages/Seeeduino/hardware/samd/1.7.9/cores/arduino/delay.h:24:0,
from /Users/gandalf/Library/Arduino15/packages/Seeeduino/hardware/samd/1.7.9/cores/arduino/Arduino.h:84,
from sketch/mpwm.h:3,
from sketch/mpwm.cpp:1:
/Users/gandalf/Library/Arduino15/packages/Seeeduino/hardware/samd/1.7.9/variants/wio_terminal/variant.h:260:15: error: expected identifier before '(' token
#define GCLK0 (36ul)
sketch/mpwm.h:11:22: note: in expansion of macro 'GCLK0'
enum class GClk {GCLK0, GCLK1, GCLK2};
/Users/gandalf/Library/Arduino15/packages/Seeeduino/hardware/samd/1.7.9/variants/wio_terminal/variant.h:260:15: error: expected '}' before '(' token
/Users/gandalf/Library/Arduino15/packages/Seeeduino/hardware/samd/1.7.9/variants/wio_terminal/variant.h:260:16: error: expected unqualified-id before numeric constant
/Users/gandalf/Library/Arduino15/packages/Seeeduino/hardware/samd/1.7.9/variants/wio_terminal/variant.h:260:16: error: expected ')' before numeric constant
In file included from sketch/mpwm.cpp:1:0:
mpwm.h:15:36: error: 'GClk' has not been declared
MatchPwm(uint32_t pin, GClk clk);
from /Users/gandalf/Google Drive/Electronics/Arduino/Wio_Match_PWM/Wio_Match_PWM.ino:1:
In file included from /Users/gandalf/Google Drive/Electronics/Arduino/Wio_Match_PWM/Wio_Match_PWM.ino:2:0:
mpwm.h:33:19: error: 'GClk' does not name a type; did you mean 'Gclk'?
const GClk _clk;
Gclk
const GClk _clk;
Gclk
sketch/mpwm.h: In constructor 'MatchPwm::MatchPwm(uint32_t)':
mpwm.h:16:61: error: 'GClk' has not been declared
explicit MatchPwm(uint32_t pin) : MatchPwm(pin, GClk::GCLK0) {};
/Users/gandalf/Library/Arduino15/packages/Seeeduino/hardware/samd/1.7.9/variants/wio_terminal/variant.h:260:15: error: expected unqualified-id before '(' token
sketch/mpwm.h:16:67: note: in expansion of macro 'GCLK0'
sketch/mpwm.h: At global scope:
mpwm.h:38:1: error: expected declaration before '}' token
exit status 1
