linkitone duo unable to connect to wifi
I have a problem with a linkitone duo.
my home wifi is protected by wpa & wpa2 aes.
When i configure the linkitione duo to client mode the wifi led blink 2 times fast then 2 time fast then one time.
Could you help ?
Have you tried resetting the Linkit Smart Duo to factory mode by following the procedure mentioned in Get Started Guide –
“press and hold the Wi-Fi button for at least 20 seconds and release to return the board to
the factory defaults. Keep in mind if you use either of these methods, it will restore to board’s default
settings and all user data will be removed from the device
Thanks and Warm Regards
