I have never seen the wiki-style of documentation and have been missing the traditional datasheets here. I am considering purchasing the LCD twig because I need a serial LCD (I wouldn’t be using any other of the Grove products), but I don’t see mentioned anywhere how much current this device uses. Any help would be nice.
Serial LCD need 5volts, if you use a Arduino don’t need a external supply, because use this voltage from USB or 9volts battery but if you use a Seeeduino Stalker you will have problems with the voltage.
