Good Afternon,
I have issues with Grove Electricity Sensor, it’s connected on Arduino Mega, I used this program :
[code]
// Function: Measure the amplitude current of the alternating current and
// the effective current of the sinusoidal alternating current.
// Hardware: Grove - Electricity Sensor
// Date: Jan 19,2013
// by www.seeedstudio.com
#define ELECTRICITY_SENSOR A0 // Analog input pin that sensor is attached to
float amplitude_current; //amplitude current
float effective_value; //effective current
pins_init();
int sensor_max;
sensor_max = getMaxValue();
Serial.print("sensor_max = ");
Serial.println(sensor_max);
//the VCC on the Grove interface of the sensor is 5v
amplitude_current=(float)sensor_max/1024*5/800*2000000;
effective_value=amplitude_current/1.414;//minimum_current=1/1024*5/800*2000000/1.414=8.6(mA)
//Only for sinusoidal alternating current
Serial.println("The amplitude of the current is(in mA)");
Serial.println(amplitude_current,1);//Only one number after the decimal point
Serial.println("The effective value of the current is(in mA)");
Serial.println(effective_value,1);
void pins_init()
pinMode(ELECTRICITY_SENSOR, INPUT);
/*Function: Sample for 1000ms and get the maximum value from the SIG pin*/
int getMaxValue()
int sensorValue; //value read from the sensor
int sensorMax = 0;
uint32_t start_time = millis();
while((millis()-start_time) < 1000)//sample for 1000ms
sensorValue = analogRead(ELECTRICITY_SENSOR);
if (sensorValue > sensorMax)
/*record the maximum sensor value*/
sensorMax = sensorValue;
return sensorMax;
}<e>[/code]</e></CODE>
The grove is set to 5V, I tested on 2 Grove, 2 sensors and 4 wires, always the same result,
The displayed value is always equal to 0 mA, when I disconnect the sensor of the random values appear (I think it’s normal ?)
Edit : I buy this sensor : <LINK_TEXT text=“https://www.seeedstudio.com/Grove-Elect … p-777.html”>https://www.seeedstudio.com/Grove-Electricity-Sensor-p-777.html</LINK_TEXT>
I do not know where the problem comes from, Benoît,
