Issues solving - Check whether I2C enabled and Grove Base Hat RPi or Grove Base Hat RPi Zero inserted
I have tried to change the I2C address 0x04 to 0x08 in the adc.py file.
Everything is updated.
how can I manually update firmware (as suggested elsewhere) -> https://files.seeedstudio.com/wiki/Grove_Base_Hat_for_Raspberry_Pi/res/MM32F031F6P6_firmware.zip
No matter what I try I get “Check whether I2C enabled and Grove Base Hat RPi or Grove Base Hat RPi Zero inserted”
How can I fix this?
I am still stuck on this. Can someone please help?
I’ve purchased a new Grove Base Hat to rule out the hardware being the source of the issue. `After installing the new hat, I am still getting the same error saying, “Check whether I2C enabled and Grove Base Hat RPi or Grove Base Hat RPi Zero inserted”
I have already changed the I2C address from 0x04 to 0x08 in the file adc.py and it still does not work.
This is my first project and I am loosing hope. Please help!
Hi, I have the same problem. Did you find a solution ?
No :frowning:
And ended up bricking my pi in the process.
Very disappointed with the support so will no longer be using grove products.
Can you check if your I2C interface is enabled with Raspberry Pi first.
You can follow the steps here:
