Is it possible to measure water conductivity with your Grove TDS Sensor? Is there a conversion or another equation that can be used. Thank You
Simply, TDS meters measure conductivity , then apply a conversion factor. Even if your meter is a TDS-only meter and does not display conductivity it still uses electrical conductivity with a conversion factor to calculate the TDS results
LOOK here
GL ![]()
