Hi!
I’m trying to install a ReSpeaker 4-Mic Array v1.2 on a Raspberry Pi 2 Model B v1.1 that runs Raspbian 11 (bullseye) following this official looking article: https://wiki.seeedstudio.com/ReSpeaker_4_Mic_Array_for_Raspberry_Pi/#getting-started.
I was able to clone the repo, run all the scripts but when I follow step 3 and run arecord -L, the card does not show up.
My output looks like this instead:
>>>arecord -L
null
Discard all samples (playback) or generate zero samples (capture)
lavrate
Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pulse
PulseAudio Sound Server
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Playback/recording through the PulseAudio sound server
playback
ac108
usbstream:CARD=Headphones
bcm2835 Headphones
USB Stream Output
usbstream:CARD=vc4hdmi
vc4-hdmi
USB Stream Output
What could be causing this?
The ReSpeaker board seems to be fine, at least I think, because I can make the LEDs light up by doing what’s described in https://wiki.seeedstudio.com/ReSpeaker_4_Mic_Array_for_Raspberry_Pi/#usage-overview.
Thanks in advance for your help and suggestions! ![]()
~ Incendor
