I2C Motor Driver V1.2
Hi all,
I just get this board, but I would like to have more information : what is this switch for ?
I trie to have a look at the wiki and also schematic, but seems there is no information on this.
Can you please help ?
Thank you
Best regards,
Denis
Replying to myself, I found the information on another post :
http://www.seeedstudio.com/wiki/Grove_-_I2C_Motor_Driver_V1.2
But still, when I plug the module all LED are light up, and it seems the I2C bus is in short as I detect no I2C…
Want can be the issue ?
Best regards,
Denis
Hi, please confirm that your I2C address is right.
such as:If your switch is 1011, your I2C address is 0x0b.
I will test as soon as I will program the firmware on the Atmega, seems there is no firmware yet.
Best regards,
Denis
Hi,there is firmware of I2C motor driver 1.2
mega8motor.zip (1.13 KB)
I do not have the AVR ISP programmer yet, bought it and I should receive it soon.
Cross fingers :slight_smile:
Br,
Denis
Enjoy yourself. Have a nice day.
I have programmed it using ATmega8 (and not ATMega8L as I do not have it in the list) and i have exactly the same issue.
All LED are on. Maybe i am doing something wrong ?
I have programmed Flash memory and not EEPROM. Also before programming something I saved the program from this flash, editing data, this is something completely different.
I do not know what to do.
Best regards
Denis
hey, does you use 0023 to driver it?
And if all leds are lighted , maybe you need modify its’ code
maybe you could try these code
[code]#include <Wire.h>
//#define MOTORSHIELDaddr 0x0f
#define SETPWMAB 0x82
#define SETFREQ 0x84
#define CHANGEADDR 0x83
#define CHANNELSET 0xaa
#define MOTOR1 0xa1
#define MOTOR2 0xa5
#define SAVEADDR ‘S’
#define NOTSAVEADDR ‘N’
static unsigned char MOTORSHIELDaddr = 0x28;
void speedAB(unsigned char spda , unsigned char spdb)
Wire.beginTransmission(MOTORSHIELDaddr); // transmit to device MOTORSHIELDaddr
Wire.send(SETPWMAB); //set pwm header
Wire.send(spda); // send pwma
Wire.send(spdb); // send pwmb
Wire.endTransmission(); // stop transmitting
delayMicroseconds(100);
void fre_pre(unsigned char pres)
Wire.send(SETFREQ); // set frequence header
Wire.send(pres); // send prescale
Wire.send(0); // need to send this byte as the third byte(no meaning)
void change_adr(unsigned char new_adr, unsigned char save_or_not)
Wire.send(CHANGEADDR); // change address header
Wire.send(new_adr); // send new address
Wire.send(save_or_not); // save the new address or not
delayMicroseconds(100); //this command needs at least 6 us
void channel(unsigned char i4) //0b 0000 I4 I3 I2 I1
// delayMicroseconds(4);
Wire.send(CHANNELSET); // channel control header
Wire.send(i4); // send channel control information
void motorAndspd( unsigned char motor_s,unsigned char Mstatus, unsigned char spd)
Wire.send(motor_s); // motor select information
Wire.send(Mstatus); // motor satus information
Wire.send(spd); // motor speed information
Wire.begin(); // join i2c bus (address optional for master)
delayMicroseconds(10); //wait for motor driver to initialization
motorAndspd(0xa1,0b01,225);
motorAndspd(0xa5,0b01,30);
delay(2000);
motorAndspd(0xa5,0b10,225);
motorAndspd(0xa1,0b10,30);
delay(2000);
change_adr(0x12, NOTSAVEADDR );
MOTORSHIELDaddr = 0x12;
for( int i = 0;i< 16;i++)
fre_pre(i);
channel(i);
delay(100);
speedAB(0 , 0);
change_adr(0x28,NOTSAVEADDR );
}[/code]
