I don’t find the other resolution option and I also try xranda command but that command doesn’t work.
Hi, you can change the resolution in the config.
can you show me? how do you change the resolution by config file?
no change by config file
can you send me you config file
To set your resolution to 640x480. Open a terminal and write:
xrandr -s 640x480
Regards,
Rachel Gomez
Size 640x480 :- Not found in available modes
I try the xrandr new and add mode both the screen divide into 3 parts.
