What do the different LED colors mean. I found documentation about what the colors mean when plugged into a PC but mine is showing a kind of pink/blue hue and I’m not sure what the means?
It also shows green which I assume means on, although my touchscreen doesn’t work. And occasionally a light yellow or brown column
I think it may be an error code? I was able to get the touchscreen work thanks to this guy’s you tube. The audio component needed to be turned around. Hope that helps someone else.
