Do you have a build spec for the turbidity sensor? Specifically the material the plastic housing is made from please? Also is this sensor built in any other housings designed to be water tight IP68+
Many thanks
Paul
Hi @pjk30cyp
You can get the spec for the turbidity sensor below.
http://files.seeedstudio.com/products/101020752/Turbidity Sensor specification.pdf
And I will update the spec to bazaar page either.
What is the reasoning behind a water sensor not being water tight? Can i put hot glue on the hole at the top to at least reduce the risk of water getting inside? Or does the hole have a function?
