I am using a grove encoder (seeedstudio.com/wiki/Grove_-_Encoder) as a user interface device.
At the moment I am using a separate grove push button as the “action” input, but I would like to use the push function of the encoder.
I can’t find a pin out for the encoder, the documents in the wiki give the 3 pins ABC as the outputs for the encoder (and common).
Is it the two other pins on the opposite side?
Thank you in advance
