Hi all, I’m running the following hardware configuration:
[list]
All Azure Sphere OS programs run fine on the board, thank you Seeed, you did a great job!
But as soon as I connect the display to the I2C bus, it seems that the
No matter which of the two IC2 connectors of the shield I use, the phenomenon is always the same. The error does not occur when I connect a Grove Temperature & Humidity Sensor (SHT31) to the shield.
Is the display defective? Does anyone have any ideas? Thanks in advance!
