I use the code provided by Grove - IMU 10DOF Wiki. How to handle the problem “MPU9250 connection failed”? The grove IMU 10DOF is used on the Intel Edison Arduino board.
1.May I know to which port of your Intel Edison arduino kit you connected the sensor.
2.Do you use grove base shield for intel edison board ?
3.Can you please post a picture of your experimental setup.
Thanks and Regards
