May I know what is the maximum length of grove cable recommended for grove sensors? When I cascade 4 cables with length 50cm, the signal lost.
Which sensor you are using? the I2C signal has some cable length limitation and the range may be lost due to that, it also depends on the sensor too.
I’m using a Grove EMG chip.
This one: https://www.seeedstudio.com/Grove-EMG-Detector-p-1737.html
Does anyone know if using a long 3.5mm extension cable is ok?
Thanks,
Jake
I’m not sure. if you have one, just tried it out and find . ![]()
