Grove Base Hat configuration I2C not detected
I have been following the instructions Exactly as given in your wiki. But they don’t seem to work. I have installed grove.py on Raspbian OS Bookworm using a virtual environment. I have tried everything but the base and its attached modules are not getting detected please help.
Did you check if the Raspberry configuration for I2C communication has been enabled?
I had to change the adc.py file, to revert the I2C address to 0x08 from 0x04. This is due to the fact that during the pandemic they were using the MM32 chip which had to use the 0x08 address on I2c. Now they have gone back to the STM32 chip that needs the address as 0x04
