Grove - 3-Axis Digitial Compass v2.0
Hi Seeed Community!
I am thinking about buying Grove - 3-Axis Digitial Compass v2.0 for my Pi Zero W.
I have 2 questions regarding this sensor:
  1. Does the Pi have to be on a flat surface for this sensor to work? Or this works as mobile phones do in any device position? The reason why I am asking is because the device I am building will always be carried around by the user.
  2. Does it need to be calibrated? The reason why I ask is because in the sensor page only speaks on how to calibrate it for Arduino and not for the Pi.
Thank you so much for your help!
Ricardo
  • It works from anywhere.
  • If you are using a scene that requires a high degree of precision, it will need to be calibrated
Thanks for your reply Baozhu!
Do you know where can I find how to calibrate it on a RPi? The sensor tutorials only mention calibration for the arduino.
I have not found a method for you to calibrate in RPI for the time being, but it is a place worth discussing in the later stage, and we will improve it in the future.
