I just started my adventure with Raspberry and Grove Base Hat. I’m using python library (from grove.display.jhd1802 import JHD1802) and it works great but backlight is always turn on. I want the backlight turn on only when I program it. It is possible?
Hi @AndrzejLanc
You can use lcd.backlight(False) to close the backlight after you programmed it.
Hi @jiachenglu
That’s my code:
from time import sleep
from grove.display.jhd1802 import JHD1802def main():
lcd = JHD1802()while True: lcd.clear() lcd.backlight(True) lcd.write("backlight true") sleep(0.5) lcd.setCursor(0, 0) lcd.backlight(False) lcd.write("backlight false") sleep(0.5)if name == ‘main’:
main()
Why it doesn’t turn off the backlight?
