Fusion PCB file question
I use Eagle 6.5.0 and gerbv 2.6.1 and when I look at my files, the dimension lines (board outline) appears on all layers?
Is that normal/ok for Seeed to process boards?
This is my first attempt…want to make sure all is OK first.
Thanks you.
yes, that will be ok!~ no problem.
And we will also apply a detail check for your board after you place the order.
Thanks!
Shuyang
