Esp32c3 - Unrecognised USB Device - Windows
Hi Team,
When I am trying to connect this one particular XIAO-ESP32C3 to my Windows system, It shows “Unrecognized Device”. I have multiple similar devices which works good on the same system.
Kindly advice if any solution.
I tried the following:
  1. Updated/ re-installed drivers.
  2. Tried different USB posts.
  3. Restarted system.
Have you tried holding down the boot button while connecting the USB?
give that a go.
Yes, it works once and I have repeat it everytime I flash.some firmware.
I was trying to get gps coordinates using a Neo 6M.
So you may want to reFlash the factory bin on it. Check the Wiki, and ESP Rftool.
my .02
Thank you for the suggestion. I will give it a try and confirm.
Regards.
@PJ_Glasso, thank you it is working now.
