I’ve tried commenting out the includes at the beginning, but then I get a completely different error I don’t know what to do with.
/usr/local/bin/arduino-cli compile --fqbn esp32:esp32:XIAO_ESP32C3:CDCOnBoot=default,CPUFreq=160,DebugLevel=none,EraseFlash=none,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,UploadSpeed=921600 --build-cache-path /tmp --output-dir /tmp/829461094/build --build-path /tmp/arduino-build-FE3D5490E5CF9C92416316CF44A15618 --library /mnt/create-efs/webide/bc/56/bc562b2744b6180fc883d8139f02552e:bfree42/libraries_v2/Adafruit GFX Library --library /mnt/create-efs/webide/bc/56/bc562b2744b6180fc883d8139f02552e:bfree42/libraries_v2/Adafruit PCD8544 Nokia 5110 LCD library --library /mnt/create-efs/webide/bc/56/bc562b2744b6180fc883d8139f02552e:bfree42/libraries_v2/DualG2HighPowerMotorShield --library /mnt/create-efs/webide/bc/56/bc562b2744b6180fc883d8139f02552e:bfree42/libraries_v2/SdFat --library /mnt/create-efs/webide/bc/56/bc562b2744b6180fc883d8139f02552e:bfree42/libraries_v2/SerialPort --library /mnt/create-efs/webide/bc/56/bc562b2744b6180fc883d8139f02552e:bfree42/libraries_v2/SparkFun MPL3115A2 Altitude and Pressure Sensor Breakout --library /home/builder/opt/libraries/esp32_ble_arduino_1_0_1 /tmp/829461094/Bluetooth_Server_Example_fromSeeed
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino:12:54: error: expected class-name before ‘{’ token
class MyCallbacks: public BLECharacteristicCallbacks {
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino:13:18: error: ‘BLECharacteristic’ has not been declared
void onWrite(BLECharacteristic *pCharacteristic) {
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino: In member function ‘void MyCallbacks::onWrite(int*)’:
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino:14:44: error: request for member ‘getValue’ in ‘* pCharacteristic’, which is of non-class type ‘int’
std::string value = pCharacteristic->getValue();
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino:24:8: error: ‘uy777777777777fg55555’ was not declared in this scope
}uy777777777777fg55555
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino: In function ‘void setup()’:
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino:31:3: error: ‘BLEDevice’ has not been declared
BLEDevice::init(“MyESP32”);
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino:32:3: error: ‘BLEServer’ was not declared in this scope
BLEServer *pServer = BLEDevice::createServer();
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino:32:3: note: suggested alternative: ‘Server’
Server
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino:32:14: error: ‘pServer’ was not declared in this scope
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino:32:14: note: suggested alternative: ‘Server’
Server
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino:32:24: error: ‘BLEDevice’ has not been declared
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino:34:3: error: ‘BLEService’ was not declared in this scope
BLEService *pService = pServer->createService(SERVICE_UUID);
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino:34:15: error: ‘pService’ was not declared in this scope
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino:34:15: note: suggested alternative: ‘Serial’
Serial
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino:36:3: error: ‘BLECharacteristic’ was not declared in this scope
BLECharacteristic *pCharacteristic = pService->createCharacteristic(
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino:36:3: note: suggested alternative: ‘Character_h’
Character_h
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino:36:22: error: ‘pCharacteristic’ was not declared in this scope
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino:36:22: note: suggested alternative: ‘Character_h’
Character_h
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino:38:42: error: ‘BLECharacteristic’ is not a class, namespace, or enumeration
BLECharacteristic::PROPERTY_READ |
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino:39:42: error: ‘BLECharacteristic’ is not a class, namespace, or enumeration
BLECharacteristic::PROPERTY_WRITE
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino:47:3: error: ‘BLEAdvertising’ was not declared in this scope
BLEAdvertising *pAdvertising = pServer->getAdvertising();
/tmp/829461094/Bluetooth_Server_Example_fromSeeed/Bluetooth_Server_Example_fromSeeed.ino:47:19: error: ‘pAdvertising’ was not declared in this scope
Error during build: exit status 1
