I am following this tutorial here ReSpeaker 6-Mic Circular Array kit for Raspberry Pi - Seeed Wiki
and when I get to this step sudo ./install.sh I get an error during the build. My build.log says
DKMS make.log for seeed-voicecard-0.3 for kernel 5.15.84-v7l+ (armv7l)
Wed 01 Mar 2023 01:30:18 PM PST
make: Entering directory '/usr/src/linux-headers-5.15.84-v7l+'
CC [M] /var/lib/dkms/seeed-voicecard/0.3/build/wm8960.o
CC [M] /var/lib/dkms/seeed-voicecard/0.3/build/ac108.o
CC [M] /var/lib/dkms/seeed-voicecard/0.3/build/ac101.o
CC [M] /var/lib/dkms/seeed-voicecard/0.3/build/seeed-voicecard.o
/var/lib/dkms/seeed-voicecard/0.3/build/seeed-voicecard.c: In function ‘seeed_voice_card_dai_link_of’:
/var/lib/dkms/seeed-voicecard/0.3/build/seeed-voicecard.c:463:8: error: implicit declaration of function ‘asoc_simple_parse_cpu’; did you mean ‘asoc_simple_parse_clk’? [-Werror=implicit-function-declaration]
463 | ret = asoc_simple_parse_cpu(cpu, dai_link, &single_cpu);
/var/lib/dkms/seeed-voicecard/0.3/build/seeed-voicecard.c:468:8: error: implicit declaration of function ‘asoc_simple_parse_codec’; did you mean ‘asoc_simple_parse_dai’? [-Werror=implicit-function-declaration]
468 | ret = asoc_simple_parse_codec(codec, dai_link);
/var/lib/dkms/seeed-voicecard/0.3/build/seeed-voicecard.c:480:8: error: implicit declaration of function ‘asoc_simple_parse_platform’; did you mean ‘asoc_simple_parse_daifmt’? [-Werror=implicit-function-declaration]
480 | ret = asoc_simple_parse_platform(plat, dai_link);
/var/lib/dkms/seeed-voicecard/0.3/build/seeed-voicecard.c:505:8: error: implicit declaration of function ‘asoc_simple_parse_clk_cpu’; did you mean ‘asoc_simple_parse_clk’? [-Werror=implicit-function-declaration]
505 | ret = asoc_simple_parse_clk_cpu(dev, cpu, dai_link, cpu_dai);
/var/lib/dkms/seeed-voicecard/0.3/build/seeed-voicecard.c:513:8: error: implicit declaration of function ‘asoc_simple_parse_clk_codec’; did you mean ‘asoc_simple_parse_clk’? [-Werror=implicit-function-declaration]
513 | ret = asoc_simple_parse_clk_codec(dev, codec, dai_link, codec_dai);
/var/lib/dkms/seeed-voicecard/0.3/build/seeed-voicecard.c:546:31: error: passing argument 1 of ‘asoc_simple_canonicalize_cpu’ from incompatible pointer type [-Werror=incompatible-pointer-types]
546 | asoc_simple_canonicalize_cpu(dai_link, single_cpu);
| struct snd_soc_dai_link *
In file included from /var/lib/dkms/seeed-voicecard/0.3/build/seeed-voicecard.c:28:
./include/sound/simple_card_utils.h:158:70: note: expected ‘struct snd_soc_dai_link_component *’ but argument is of type ‘struct snd_soc_dai_link *’
158 | void asoc_simple_canonicalize_cpu(struct snd_soc_dai_link_component *cpus,
/var/lib/dkms/seeed-voicecard/0.3/build/seeed-voicecard.c:548:36: error: passing argument 1 of ‘asoc_simple_canonicalize_platform’ from incompatible pointer type [-Werror=incompatible-pointer-types]
548 | asoc_simple_canonicalize_platform(dai_link);
./include/sound/simple_card_utils.h:156:75: note: expected ‘struct snd_soc_dai_link_component *’ but argument is of type ‘struct snd_soc_dai_link *’
156 | void asoc_simple_canonicalize_platform(struct snd_soc_dai_link_component *platforms,
/var/lib/dkms/seeed-voicecard/0.3/build/seeed-voicecard.c:548:2: error: too few arguments to function ‘asoc_simple_canonicalize_platform’
./include/sound/simple_card_utils.h:156:6: note: declared here
At top level:
/var/lib/dkms/seeed-voicecard/0.3/build/seeed-voicecard.c:263:12: warning: ‘asoc_simple_parse_dai’ defined but not used [-Wunused-function]
263 | static int asoc_simple_parse_dai(struct device_node *node,
cc1: some warnings being treated as errors
make[1]: *** [scripts/Makefile.build:289: /var/lib/dkms/seeed-voicecard/0.3/build/seeed-voicecard.o] Error 1
make[1]: *** Waiting for unfinished jobs....
/var/lib/dkms/seeed-voicecard/0.3/build/ac108.c:1148:3: error: ‘const struct snd_soc_dai_ops’ has no member named ‘digital_mute’
1148 | .digital_mute = ac108_aif_mute,
/var/lib/dkms/seeed-voicecard/0.3/build/ac108.c:1148:18: error: initialization of ‘int (*)(struct snd_pcm_substream *, int, struct snd_soc_dai *)’ from incompatible pointer type ‘int (*)(struct snd_soc_dai *, int)’ [-Werror=incompatible-pointer-types]
/var/lib/dkms/seeed-voicecard/0.3/build/ac108.c:1148:18: note: (near initialization for ‘ac108_dai_ops.bespoke_trigger’)
In file included from /var/lib/dkms/seeed-voicecard/0.3/build/wm8960.c:28:
/var/lib/dkms/seeed-voicecard/0.3/build/wm8960.c: In function ‘wm8960_configure_clocking’:
/var/lib/dkms/seeed-voicecard/0.3/build/sound-compatible-4.18.h:34:36: error: implicit declaration of function ‘snd_soc_component_read32’; did you mean ‘snd_soc_component_read’? [-Werror=implicit-function-declaration]
34 | #define snd_soc_read snd_soc_component_read32
/var/lib/dkms/seeed-voicecard/0.3/build/wm8960.c:619:15: note: in expansion of macro ‘snd_soc_read’
619 | u16 iface1 = snd_soc_read(codec, WM8960_IFACE1);
/var/lib/dkms/seeed-voicecard/0.3/build/wm8960.c: At top level:
/var/lib/dkms/seeed-voicecard/0.3/build/wm8960.c:1239:3: error: ‘const struct snd_soc_dai_ops’ has no member named ‘digital_mute’
1239 | .digital_mute = wm8960_mute,
/var/lib/dkms/seeed-voicecard/0.3/build/wm8960.c:1239:18: error: initialization of ‘int (*)(struct snd_pcm_substream *, struct snd_soc_dai *)’ from incompatible pointer type ‘int (*)(struct snd_soc_dai *, int)’ [-Werror=incompatible-pointer-types]
/var/lib/dkms/seeed-voicecard/0.3/build/wm8960.c:1239:18: note: (near initialization for ‘wm8960_dai_ops.prepare’)
make[1]: *** [scripts/Makefile.build:289: /var/lib/dkms/seeed-voicecard/0.3/build/ac108.o] Error 1
make[1]: *** [scripts/Makefile.build:289: /var/lib/dkms/seeed-voicecard/0.3/build/wm8960.o] Error 1
make: *** [Makefile:1902: /var/lib/dkms/seeed-voicecard/0.3/build] Error 2
make: Leaving directory '/usr/src/linux-headers-5.15.84-v7l+'
Any ideas how to fix this? I installed the 32-bit Raspberry Pi OS
