I have bought two Electronic brick - 3-Axis Accelerometer Module (BETA),the power and groud pin in this brick seems different with Electronic Brick Chassis IIC port,so I can not use Fully buckled 4 wire cable,otherwise the power will connect to ground.
I have tested,seems your 3-Axis Accelerometer Module make a mistake, label the wrong power and ground pins.
The power and groud pin in the 3-Axis Accelerometer Module is the not same as Electronic Brick Chassis IIC port,your document have a mistake.As you see Electronic Brick Chassis IIC port it is vcc ,gnd,sda,scl.
