DSO Quad .CSV data
I was wondering what was the best way to use the CSV output file created by the Quad. Clearly you can input the data to a spreadsheet but there are two problems:
  1. There is no time data to reference the four data outputs and
  2. The amplitude data does not appear to be voltage as seen on the screen
So my questions are will this be updated later to make this output more useful and in the meantime has someone else worked out how to derive both time and voltage scaling for the data?
Dear customer,
If you save the DATA, sorry to tell you that is a bug, it is record by the lined on the screen position not voltage.Also you can not seen any time in it.There is finding some way to fix it.
So may be best way is shoot a picture for save, that could view every parameter in it.
Hope can help you.
Best regards,
Yuri
