Hi everybody, thanks for your time
I have a 2.81 hardware version of a Ds203 oscilloscope. Suddenly, from one day to the next, I got a “fpga configuration error”, no faulty firmware change or incorrect version, just stopped to work. I’ve tried all the things I’ve read in forums, change firmware, serial programmer but no success at all.
I don’t know if it can be a hardware issue perhaps. What do you think?? If so do you believe that fisically change the arm or the fpga could work??
Thank you in advance
The “FPGA configuration error” on your DS203 could indeed be a hardware issue. If software fixes haven’t worked, it’s possible that the FPGA or ARM chip has failed. Physically replacing the FPGA or ARM chip might resolve the issue, but this requires precision soldering skills and the right equipment.
Consider seeking professional repair services if you’re not experienced with this kind of hardware work. Read More
The “FPGA configuration error” on your DS203 could be caused by a hardware fault. If software solutions haven’t resolved the issue, the problem may lie with the FPGA or ARM chip itself. Replacing these components could fix the error, but it requires skilled soldering and proper equipment.
If you’re not familiar with hardware repairs, it’s advisable to seek professional help to avoid causing further damage.
