Hi to all,
Once I know how to do it I am fine. But I need your help. We want to have a remote switch to turn off a pump a simple on and off.
I have found this.
The pump is 8 volt.
Question. I cannot see a wiring diagram.
Question. The transmitter. Where do you get the key cases from the buttons etc.
Question. Do I need the software to install the code.
Is there anyone willing to take me through the process.
Brenden
Hi @Gonecamping1975, You can find all the Instruction from the Grove - 315MHz RF Kit WiKi Page. from wiring to example code, Please let me know if you find any difficulties to get started.
Thanks for the reply. Are there any cases for the sender module. What do you use to make the sender module into an actual key fob so you can press to turn off and on?
Is there any to suit ?
Brenden
meilleur taux[quote=“Gonecamping1975, post:1, topic:251894”]
The pump is 8 volt.
Brenden
[/quote]
Hi i think i could be that someone you are looking for
