My final goal is to use the Wio Terminal as a BLE receiver to display data measured on an Arduino nano BLE 33 Sense. I have noticed that if I have more than 3 characteristic I get the message Malloc Failed.
Here is my program on the Arduino nano
* Device: Arduino Nano 33 BLE Sense
* Peripheral
* The values of the integrated temperature sensor and
* accelerometer are sent using BLE.
* created from sketch_nanoBLEsense33_BLE_acc_T_peripheral_v9_MAX30102
#include <ArduinoBLE.h>
#include <Arduino_LSM9DS1.h> //accelerometer sensor
#include <Arduino_HTS221.h> // temperature sensor
//#include <Wire.h>
//#include "MAX30105.h"
//MAX30105 particleSensor;
int const d_t=0; //number of decimal to keep for the temperature
int const d_ir=0;
int const d_a=2;
//float values read by the sensor
float tSensor=25;
//float irSensor=0;
float xSensor=0;
float ySensor=0;
float zSensor=0;
//integer variables to send via BLE
int tBLE=floor(tSensor*pow(10,d_t)+0.5);
//int irBLE=floor(irSensor*pow(10,d_ir)+0.5);
int xBLE=xSensor*pow(10,d_a);
int yBLE=ySensor*pow(10,d_a);
int zBLE=zSensor*pow(10,d_a);
int compteur=0;
BLEService SensorService("1101");
BLEUnsignedIntCharacteristic XChar("2101", BLERead | BLENotify);
BLEUnsignedIntCharacteristic YChar("2102", BLERead | BLENotify);
BLEUnsignedIntCharacteristic ZChar("2103", BLERead | BLENotify);
BLEUnsignedIntCharacteristic TChar("2104", BLERead | BLENotify);
//BLEUnsignedIntCharacteristic IRChar("2107", BLERead | BLENotify);
Serial.begin(115200);
//initialisation of the accelerometer
if (!IMU.begin()) {
Serial.println("Failed to initialize IMU!");
while (1);
// initialisation of the temperature sensor
HTS.begin();
while (!Serial);
pinMode(LED_BUILTIN, OUTPUT);
//initialisation of the BLE
if (!BLE.begin()) {
Serial.println("BLE failed to Initiate");
//delay(500);
while (1);
BLE.setLocalName("Arduino XYZT (peripheral)");
BLE.setAdvertisedService(SensorService);
SensorService.addCharacteristic(TChar);
//SensorService.addCharacteristic(IRChar);
SensorService.addCharacteristic(XChar);
SensorService.addCharacteristic(YChar);
SensorService.addCharacteristic(ZChar);
BLE.addService(SensorService);
XChar.writeValue(xBLE);
YChar.writeValue(yBLE);
ZChar.writeValue(zBLE);
TChar.writeValue(tBLE);
// IRChar.writeValue(irBLE);
BLE.advertise();
Serial.println("Arduino XYZT peripheral device is now active, waiting for connections...");
// //initialisation from Example4_HeartBeatPlotter
// Serial.println("Initializing...");
// // Initialize sensor
// if (!particleSensor.begin(Wire, I2C_SPEED_FAST)) //Use default I2C port, 400kHz speed
// Serial.println("MAX30105 was not found. Please check wiring/power. ");
// while (1);
// //Setup to sense a nice looking saw tooth on the plotter
// byte ledBrightness = 0x1F; //Options: 0=Off to 255=50mA
// byte sampleAverage = 8; //Options: 1, 2, 4, 8, 16, 32
// byte ledMode = 3; //Options: 1 = Red only, 2 = Red + IR, 3 = Red + IR + Green
// int sampleRate = 100; //Options: 50, 100, 200, 400, 800, 1000, 1600, 3200
// int pulseWidth = 411; //Options: 69, 118, 215, 411
// int adcRange = 4096; //Options: 2048, 4096, 8192, 16384
// particleSensor.setup(ledBrightness, sampleAverage, ledMode, sampleRate, pulseWidth, adcRange); //Configure sensor with these settings
// //Arduino plotter auto-scales annoyingly. To get around this, pre-populate
// //the plotter with 500 of an average reading from the sensor
// //Take an average of IR readings at power up
// const byte avgAmount = 64;
// long baseValue = 0;
// for (byte x = 0 ; x < avgAmount ; x++)
// baseValue += particleSensor.getIR(); //Read the IR value
// baseValue /= avgAmount;
// //Pre-populate the plotter so that the Y scale is close to IR values
// for (int x = 0 ; x < 500 ; x++)
// Serial.println(baseValue);
Serial.print("inside the void loop \t");
compteur++;
Serial.print("compteur void loop \t");
Serial.println(compteur);
tSensor=HTS.readTemperature();
Serial.print(" tSensor \t");
Serial.println(tSensor);
// irSensor=particleSensor.getIR();
// Serial.print(" irSensor \t");
// Serial.println(irSensor); //Send raw data to plotter
if (IMU.accelerationAvailable()) {
IMU.readAcceleration(xSensor, ySensor, zSensor);
Serial.print("xSensor ");
Serial.print(xSensor);
Serial.print(" - ySensor ");
Serial.print(ySensor);
Serial.print(" - zSensor ");
Serial.print(zSensor);
BLEDevice central = BLE.central();
BLE.advertise();
if (central) {
Serial.print("Connected to central: ");
Serial.print("* Device MAC address: ");
Serial.println(central.address());
if (central.connected()) { // doesn't work if it is a while loop
// send temperature data
Serial.print(" tBLE \t");
Serial.println(tBLE);
Serial.print(" TChar ");
Serial.println(TChar.value());
// //send IR data
// irBLE=floor(irSensor*pow(10,d_ir)+0.5);
// Serial.print(" irBLE \t");
// Serial.println(irBLE);
// Serial.print(" IRChar ");
// Serial.println(IRChar.value());
//send accelerometer datas
//xBLE=xSensor*pow(10,d_a);
// Serial.print("xBLE ");
// Serial.print(xBLE);
Serial.print(" - yBLE ");
Serial.print(yBLE);
Serial.print(" - zBLE ");
Serial.print(zBLE);
//XChar.writeValue(xBLE);
// Serial.print("XChar ");
// Serial.print(XChar.value());
Serial.print(" - YChar ");
Serial.print(YChar.value());
Serial.print(" - ZChar ");
Serial.print(ZChar);
Serial.println("");
//Serial.print("Disconnected from central: ");
//Serial.println(central.address());
and here the program for the Wio
* A BLE client example that is rich in capabilities.
* There is a lot new capabilities implemented.
* author unknown
* updated by chegewara
* created from wio_BLEclient_v5_MAX30102
#include "rpcBLEDevice.h"
#include <BLEScan.h>
#include <BLEAdvertisedDevice.h>
#include"TFT_eSPI.h"
TFT_eSPI tft;
// The remote service we wish to connect to.
//static BLEUUID serviceUUID(0xFEE0);
static BLEUUID serviceUUID(0x1101);
// The characteristic of the remote service we are interested in.
//static BLEUUID charUUID(0x2A2B);
//static BLEUUID XcharUUID(0x2101);
static BLEUUID YcharUUID(0x2102);
static BLEUUID ZcharUUID(0x2103);
static BLEUUID TcharUUID(0x2104);
//static BLEUUID IRcharUUID(0x2107);
static boolean doConnect = false;
static boolean connected = false;
static boolean doScan = false;
static BLERemoteCharacteristic* pTChar;
//static BLERemoteCharacteristic* pXChar;
static BLERemoteCharacteristic* pYChar;
static BLERemoteCharacteristic* pZChar;
//static BLERemoteCharacteristic* pIRChar;
static BLEAdvertisedDevice* myDevice;
//uint8_t bd_addr[6] = {0xD9, 0x91, 0xC0, 0x66, 0xAD, 0xF9};
uint8_t bd_addr[6] = {0x43, 0x89, 0x1A, 0x4E, 0xEA, 0xDC};
BLEAddress BattServer(bd_addr);
//float tmp_T(0),deltaTmp_T(0);
int compteur=0;
int compteur2=0;
int compteur3=0;
//int const d_ir=-2;
static void temperatureNotifyCallback(
BLERemoteCharacteristic* pTChar,
uint8_t* pTData,
size_t length,
bool isNotify) {
Serial.print("Notify callback for temperature characteristic ");
Serial.print(pTChar->getUUID().toString().c_str());
Serial.print(" of data length ");
Serial.println(length);
Serial.print("data: ");
Serial.println(*(uint8_t *)pTData);
compteur3++;
Serial.print("compteur temperatureNotifyCallback \t");
Serial.println(compteur3);
//Serial.println(*pTData);
//Serial.println(pTData[0]);
tft.fillRect(200, 10, 100, 30, TFT_WHITE);
tft.drawString(String(*pTData), 200, 10);
//static void xNotifyCallback(
// BLERemoteCharacteristic* pXChar,
// uint8_t* pXData,
// size_t length,
// bool isNotify) {
// Serial.print("Notify callback for X characteristic ");
// Serial.print(pXChar->getUUID().toString().c_str());
// Serial.print(" of data length ");
// Serial.println(length);
// Serial.print("data: ");
// Serial.println(*(uint8_t *)pXData);
// tft.fillRect(200, 40, 100, 30, TFT_WHITE);
// tft.drawString(String(*pXData), 200, 40);
static void yNotifyCallback(
BLERemoteCharacteristic* pYChar,
uint8_t* pYData,
size_t length,
bool isNotify) {
Serial.print("Notify callback for Y characteristic ");
Serial.print(pYChar->getUUID().toString().c_str());
Serial.println(*(uint8_t *)pYData);
tft.fillRect(200, 70, 100, 30, TFT_WHITE);
tft.drawString(String(*pYData), 200, 70);
static void zNotifyCallback(
BLERemoteCharacteristic* pZChar,
uint8_t* pZData,
size_t length,
bool isNotify) {
Serial.print("Notify callback for Z characteristic ");
Serial.print(pZChar->getUUID().toString().c_str());
Serial.println(*(uint8_t *)pZData);
tft.fillRect(200, 100, 100, 30, TFT_WHITE);
tft.drawString(String(*pZData), 200, 100);
//static void irNotifyCallback(
// BLERemoteCharacteristic* pIRChar,
// uint8_t* pIRData,
// size_t length,
// bool isNotify) {
// Serial.print("Notify callback for IR characteristic ");
// Serial.print(pIRChar->getUUID().toString().c_str());
// Serial.println(*(uint8_t *)pIRData);
// tft.drawString(String(*pIRData), 200, 130);
class MyClientCallback : public BLEClientCallbacks {
void onConnect(BLEClient* pclient) {
void onDisconnect(BLEClient* pclient) {
connected = false;
Serial.println("onDisconnect");
bool connectToServer() {
Serial.println("Inside bool connectToServer ");
Serial.print("Forming a connection to ");
Serial.println(myDevice->getAddress().toString().c_str());
BLEClient* pClient = BLEDevice::createClient();
Serial.println(" - Created client");
pClient->setClientCallbacks(new MyClientCallback());
// Connect to the remove BLE Server.
pClient->connect(myDevice); // if you pass BLEAdvertisedDevice instead of address, it will be recognized type of peer device address (public or private)
Serial.println(" - Connected to server");
// Obtain a reference to the service we are after in the remote BLE server.
BLERemoteService* pRemoteService = pClient->getService(serviceUUID);
Serial.println(serviceUUID.toString().c_str());
if (pRemoteService == nullptr) {
Serial.print("Failed to find our service UUID: ");
pClient->disconnect();
return false;
Serial.println(" - Found our service");
// Obtain a reference to the characteristic in the service of the remote BLE server.
//pRemoteCharacteristic = pRemoteService->getCharacteristic(charUUID);
pTChar = pRemoteService->getCharacteristic(TcharUUID);
//pXChar = pRemoteService->getCharacteristic(XcharUUID);
pYChar = pRemoteService->getCharacteristic(YcharUUID);
pZChar = pRemoteService->getCharacteristic(ZcharUUID);
//pIRChar = pRemoteService->getCharacteristic(IRcharUUID);
//if (pTChar == nullptr || pIRChar == nullptr || pXChar == nullptr || pYChar == nullptr || pZChar == nullptr) {
//if (pXChar == nullptr || pYChar == nullptr || pZChar == nullptr) {
//if (pTChar == nullptr || pXChar == nullptr || pYChar == nullptr || pZChar == nullptr) {
if (pTChar == nullptr || pYChar == nullptr || pZChar == nullptr) {
//if (pTChar == nullptr) {
Serial.print("Failed to find our characteristic UUID ");
// Serial.println(TcharUUID.toString().c_str());
return false;
Serial.println(" - Found our characteristic");
// Read the temperature characteristic value
if(pTChar->canRead()) {
Serial.println(" - can read start");
std::string value = pTChar->readValue();
Serial.print("The characteristic value was: ");
Serial.println(value.c_str());
if(pTChar->canNotify())
pTChar->registerForNotify(temperatureNotifyCallback);
// if(pXChar->canRead()) {
// Serial.println(" - can read start");
// std::string value = pXChar->readValue();
// Serial.print("The characteristic value was: ");
// Serial.println(value.c_str());
// if(pXChar->canNotify())
// pXChar->registerForNotify(xNotifyCallback);
if(pYChar->canRead()) {
std::string value = pYChar->readValue();
if(pYChar->canNotify())
pYChar->registerForNotify(yNotifyCallback);
if(pZChar->canRead()) {
std::string value = pZChar->readValue();
if(pZChar->canNotify())
pZChar->registerForNotify(zNotifyCallback);
// // Read the IR characteristic value
// if(pIRChar->canRead()) {
// std::string value = pIRChar->readValue();
// //int irValue=value*pow(10,d_ir);
// if(pIRChar->canNotify())
// pIRChar->registerForNotify(irNotifyCallback);
compteur2 ++;
Serial.print("compteur connect to server");
Serial.println(compteur2);
connected = true;
return true;
Serial.println("End of bool connectToServer ");
}// bool connectToServer
* Scan for BLE servers and find the first one that advertises the service we are looking for.
* Also in BLEscan example but with a shorter onresult
class MyAdvertisedDeviceCallbacks: public BLEAdvertisedDeviceCallbacks { // crée une classe MyAdvertisedDeviceCallbacks qui hérite de la classe BLEAdvertisedDeviceCallbacks
* Called for each advertising BLE server.
void onResult(BLEAdvertisedDevice advertisedDevice) {
Serial.println("Inside onResult ");
Serial.print("BLE Advertised Device found: ");
Serial.println(advertisedDevice.toString().c_str());
// We have found a device, let us now see if it contains the service we are looking for.
//int memcmp ( const void * ptr1, const void * ptr2, size_t num );
//: Compares the first num bytes of the block of memory pointed by ptr1 to the first num bytes pointed by ptr2,
//returning zero if they all match or a value different from zero representing which is greater if they do not.
if (memcmp(advertisedDevice.getAddress().getNative(),BattServer.getNative(), 6) == 0) {
Serial.print("BATT Device found: ");
BLEDevice::getScan()->stop();
Serial.println("new BLEAdvertisedDevice");
myDevice = new BLEAdvertisedDevice(advertisedDevice);
Serial.println("new BLEAdvertisedDevice done");
doConnect = true;
doScan = true;
Serial.print("doConnect status");
Serial.println(doConnect);
}// onResult
}; // MyAdvertisedDeviceCallbacks
//initialisation of the screen
tft.begin();
tft.setRotation(3);//
tft.fillScreen(TFT_WHITE);
tft.setTextSize(2); //sets the size of text
tft.setTextColor(TFT_BLACK); //sets the text colour to black
tft.drawString("Temperature", 0, 10);
tft.drawString("AccX", 0, 40);
tft.drawString("AccY", 0, 70);
tft.drawString("AccZ", 0, 100);
tft.drawString("IR", 0, 130);
tft.drawString("SpO2", 0, 160);
//initialisation of the serial connection
while(!Serial){};
//delay(2000);
Serial.println("Starting Arduino BLE Client application...");
BLEDevice::init("");
} // End of setup.
// This is the Arduino main loop function.
compteur++;
Serial.print("doConnect status ");
if (doConnect != true) {
// Retrieve a Scanner and set the callback we want to use to be informed when we
// have detected a new device. Specify that we want active scanning and start the
// scan to run for 5 seconds.
Serial.println("scanning");
BLEScan* pBLEScan = BLEDevice::getScan(); // get scanner from our client device
pBLEScan->setAdvertisedDeviceCallbacks(new MyAdvertisedDeviceCallbacks()); // behaviour of the scanner each time it find another bluetooth device
//setAdvertisedDeviceCallbacks, setInterval, setWindow, setActiveScan methods from the librairy BLEscan
pBLEScan->setInterval(1349); // period between 2 active scans
pBLEScan->setWindow(449); // active scan time range
pBLEScan->setActiveScan(true);//beginning of the scan
pBLEScan->start(5, false);
// If the flag "doConnect" is true then we have scanned for and found the desired
// BLE Server with which we wish to connect. Now we connect to it. Once we are
// connected we set the connected flag to be true.
if (doConnect == true) {//static boolean initialized as false
Serial.println("inside the if(doConnect==true) loop");
if (connectToServer()) {
Serial.println("inside the ConnectToServer loop");
Serial.println("We are now connected to the BLE Server.");
} else {
Serial.println("We have failed to connect to the server; there is nothin more we will do.");
Serial.println("end of if connectToServer");
//doConnect = false;
//display time information
Serial.println("");
} // End of loop
These programs work well if for instance I comment every thing related to xSensor, xChar…
Anyone would know how to deal with this problem?
Best regards,
Alice
