Connector on NFC Reader
I have a couple question about this NFC reader: https://www.seeedstudio.com/Grove-NFC.html. We want to plug it into a solution with a custom PCB.
  1. Is I2C coming out of the white connector?
  2. If yes, what is the part number (Digikey) of that connector? I know you sell the cable assemblies, but what connector do I need to put on my custom PCB for the cable assembly to plug into.
Hi @Wayne, Yes, The White connector is called Grove Adapter.
You can use this Grove Female Header 4-pin, 2.0mm pitch, DIP Grove Female Header to attach you custom PCB.
The grove connector cable is available in different sizes.
