In particular I’m having trouble compiling the demo sketch in the seeed tutorial at
I#### Adding Grove - Wio-E5 devices to the Helium console
I followed these steps
- Login to helium console
- Go to Devices
- Add new device
- Enter in a device name
- The 3 keys mentioned above are created.
- Now in Arduino IDE, load the example from the sensors folder lightsensor-send-data.ini
- You will modify this sketch to connect to the Helium network.
- Select the LoRaWAN® band you wish to use… The available frequency bands are in the comments of the code below. In the tutorials we use, the default is the EU868 band.
- The US915 band is commonly used in North America
- Place the the Helium generated DevEUI, AppEUI, and AppKey in the sketch for deveui[] , appeui, appkey[] array initialization.
- Upload the code for Wio Terminal and open the serial port monitor of Arduino IDE, set the baud rate to 9600 and observe the setting.
RESULTS
Verify failed with disk91_LoRaE5.h not found?
OH YES… I needed to clone the zip file from GitHub - disk91/Disk91_LoRaE5: Ardunio LoRa E5 driver for WIO and other Boards
Then I went to the Arduino IDE. And selected the zip file
NOW I’m getting an error.
exit status 1
Compilation error: invalid conversion from ‘char*’ to ‘uint8_t* {aka unsigned char*}’ [-fpermissive]
It’s occurring here I think
* if ( ! lorae5.setup(
* Frequency,
* deveui,
* appeui,
* appkey
* // (uint8_t)deveui,
* // (uint8_t)appeui,
* // (uint8_t)appkey
* // (char*)deveui,
* // (char*)appeui,
* // (char*)appkey
- Is It Because the 3 args in lorae5.setup() are uint8_t?
- char deveui[] = “”;
- char appeui[] = “”;
- char appkey[] = “”;
Did I get the Wrong Disk9LoarE5 library?
I’m using Arduino IDE 2.0?
I tried casting but that Did Not help?
Has anybody gone thru this tutorial with sucess?
