my question is. ¿How can i change default apn for connect to internet?
my apn parameters are:
APN: ac.vodafone.es
USER: vodafone
PASS: vodafone
I don’t have a proxy.
Regards.
David.
APN: ac.vodafone.es
USER: vodafone
PASS: vodafone
Regards.
David.
Modify the define statements in the ‘https.cpp’ file.
located here…
Arduino_IDE_for_RePhone-master\hardware\arduino\mtk\libraries\Network_https\utility
Ok,
but in tghe struct vm_gsm_gprs_apn_info_t not exists parameters like:
-user without proxy
-pass
Are you working Arduino or Eclipse IDE?
I’m using Eclipse and I’ve verified configure my APN sucessfully.
In case:
[code]
#define USING_PROXY VM_FALSE /* Whether your SIM uses proxy /
#define PROXY_ADDRESS “” / The proxy address /
#define PROXY_PORT / The proxy port */
void set_custom_apn(void)
vm_gsm_gprs_apn_info_t apn_info;
memset(&apn_info, 0, sizeof(apn_info));
strcpy(apn_info.apn, "ac.vodafone.es"); //I think that this field is optional
strcpy(apn_info.proxy_username, "vodafone");
strcpy(apn_info.proxy_password, "vodafone");
vm_gsm_gprs_set_customized_apn_info(&apn_info);
}[/code]
