I’m trying to use different components like LCD 16x2, Force Sensor and more using the grove with the example codes found here and nothing seems to work.
has anyone encountered problems with this board?
thank you
What kind of problem you are facing? any error?
Uplaoding seems to be fine…
when i try the blink example it works but other examples using the grove dont work.
the LCD doesn’t display “Hallo World”
and if i try to read the force sensor I see nothing in the plotter or monitor.
thanks
Which force sensor are you using? and can you share the code?
