Cannot connect RaspberryPi LoraWan Gateway to LORIOT server
Hello!
I have been trying to set up the Seeeds LoraWan gateway. I have been following this the documentation.
on step 1, i) I put this commands into the RaspberryPi (which is connected to the internet and can normally access everything)
cd /home/rxhf/loriot/1.0.2
sudo systemctl stop pktfwd
sudo gwrst
wget https://cn1.loriot.io/home/gwsw/loriot-risinghf-rhf2s008-rhf1257-SPI-0-latest.bin -O loriot-gw.bin
chmod +x loriot-gw.bin
but I get this “unreachable” response
… failed: Connection timed out.
Retrying.
Could you help me out here? What could be blocking it? The access outside is normal, there is no FW configured or anything that could be blocking
Thanks in advance!
Ana
