Is the pinout similar enough to a Pi so this one might work - LetsTrust TPM for Raspberry Pi | The Pi Hut?
Thanks!
Thanks!
If you’re considering using this TPM module with a Raspberry Pi, it’s important to note that it should work seamlessly as long as you adhere to the pinout specifications and the SPI configuration. The LetsTrust TPM can connect directly to the Raspberry Pi’s GPIO pins and is compatible with Raspbian and other Linux distributions that support the required TPM configurations.
