Cable in the way (Grove)
Some Grove sensors are designed poorly which makes it difficult to install them. For example, the sound sensor has the microphone lower than the 4-pin cable port so I can’t install it into an enclosure with just the microphone being visible because, even if the cable port and mic were on the same level, the cable will be in the way.
Any thoughts or suggestions?
What do you mean? Here is the link to the Sound Sensor that I have: seeedstudio.com/depot/grove- … p-752.html
