I’ve found a minor but irritating bug in the Grove shield library for Azure Sphere. The original code looks like:
[code]static int baudrate_conf(int *fd, UART_BaudRate_Type baudrate)
static uint8_t trial = 0;
uint8_t d0, d1;
uint8_t conf[4] = { 0 };
close(*fd);
*fd = GroveUART_Open(MT3620_RDB_HEADER2_ISU0_UART, 9600);
while (true)
d0 = 0, d1 = 0;
[/code]
However, if GroveUART_Open fails, the baudrate_conf routine fails to return due to the loop immediately following. Instead, the code might look like the following:
uint8_t d0, d1;
close(*fd);
//Check for errors
if (*fd == -1)
if (EACCES == errno)
Log_Debug("[error] Failed to open COM port. Is manifest configured correctly?");
else
Log_Debug("[error] Failed to open COM port. Error %d", errno);
return errno;
while (true)
d0 = 0, d1 = 0;
[/code]
I also modified the return from void to int and returned an error code for both baudrate_conf and the calling routine GroveShield_Initialize so that the main code can determine if the initialization failed. Note that forgetting to set the app_manifest.json file is pretty easy error to make.
Thanks for the Azure Sphere supporting products.
